Downloads & Updates
Software downloads and updates are for users who have purchased full versions of Bluebeam products. If you need to install a licenced version of our software for the first time, or install an update to an existing version, you are at the right place. Select from the following download links and verify that the option you select matches the software product on your digital licence certificate, otherwise your Bluebeam serial number and product key will not unlock the software you install. The trial software is the full version limited to the time of the trial period, so you do not need to re-install the software if the current version is already installed.
Bluebeam Revu licences are tied to the major version number (e.g. Revu 11, 12, 2016 or Revu Mac 1) and edition (Standard, CAD, eXtreme) and are valid for all updates to this version. For example, if you have a Revu CAD 12 licence, you can install up to Revu CAD 12.6.
To find the version number of the installed software:
  1. Open Bluebeam Revu
  2. Click the Help menu and select About
  3. The product name and version number will be displayed in the upper left corner.
Note: Please refer to the Bluebeam Revu Compatibility Chart to confirm that the version of Bluebeam Revu you want to install is compatible with the operating system and associated software on your machine.
Make sure you only download and install the edition and version number listed on your licence certificate.
Revu Standard
Major Version Release Number Installer
Revu 2017 2017.0.30 Download Click here if you're updating from 2017.x.
Revu 2016 2016.5.2 Download Click here if you're updating from 2016.5.x.
Revu 2015 2015.6 Download
Revu 12 12.6 Download
Revu 11 11.7 Download
Revu 10 10.2.3 Download
Revu 9 9.5.1 Download
Revu 8 8.5.1 Download 32-Bit Download 64-bit
Revu 7 7.2.1 Download 32-bit Download 64-bit
Revu 6 6.5.4 Download 32-bit Download 64-bit
Revu 5 5.5.3 Download 32-bit Download 64-bit
Revu CAD
Revu 2016 2016.5.2 Download Click here if you're updating from 2016.5.0.
Revu 8 8.5.1 Download 32-bit Download 64-bit
Revu eXtreme
Bluebeam Vu
Vu 2017 2017.0.30 Download
Vu 2016 2016.5 Download
Vu 2015 2015.6 Download
Vu 12 12.6 Download
Vu 11 11.7 Download
Vu 10 10.2.3 Download
Bluebeam Revu Mac
1.0 1.9.3 Download
Bluebeam Q
4.5.3 32-BIT 64-BIT
Studio Enterprise
3.1 Download
Legacy
Bluebeam software versions 1 through 4 are only compatible with Windows 2000 and XP, which Microsoft no longer supports. With this in mind, we’re unable to provide support for Revu versions that are incompatible with currently supported versions of Windows. Please refer to our compatibility information for further details.
If you’d like to run Bluebeam Revu on a supported version of Windows, you can purchase the current version online from the Bluebeam Store.
Product Name Version Installer
Bluebeam PDF Revu 4.7.1
Bluebeam PDF Revu AutoCAD Edition 4.7.1
Bluebeam PDF Revu SolidWorks Edition 4.7.1
Bluebeam Lite 2.5.2 1.6.1
Bluebeam Conversion Server 3.5.1 2.0 1.5
Pushbutton Plus for AutoCAD 3.5.2
Pushbutton Plus for SolidWorks 3.5.2
Pushbutton PDF for SolidWorks 2.4.1
Pushbutton PDF 2.2.8
